Cannot transmit messages in XNET Bus Monitor
Hello, I want to use the XNET Bus Monitor to transmit a message, but the Measurement menu doesn't contain the item "Transmit Frame" like the documentation says it should. I know it works only for CAN, but I do have CAN, the interface is called CAN1...
What do I need to do?
(4,385 Views)
Accepted by topic author Manudelavega
What version of XNET are you using? In the most rescent version (16.1) the functionality in quesiton has been moved to a tab labeled Transmit.
Jeff L
(4,351 Views)
I'm using 15.3.
Edit: OK I just realized that 15.3 also has that Transmit tab!!
(4,347 Views)
