Channel exists in multiple messages
I've a problem with the CAN-Channels i've importet into the MAX.
How the subject says: I have in some messages the same channel names.
Is there a way  to use a specific message with a channel-name?
Thanks for Help!
Chris
(4,882 Views)
hi,
dont mistake me..sometimes this happen..
i.) check whether same channel name exists in different messages..in this case conflict will arise ..
ii.)if u want u can give ur channel name as ur message name ..no issue will come..
if i am not right pls reply ...
(4,878 Views)
hi, thanks for your fast response.
yes you are rigth i've the same channel name in different messages. Do you know a way to use a certain message of these messages with the same channel name inside the message?
Or is their no other way to delete or rename the other messages / channels?
Thanks for help. With best regards
Christian
(4,872 Views)
hi,
you can rename the channel/message name by ..  open MAX>>right click the chan/msg nem>>open properties>> one window will open>>in that edit the name...
after doing this save the chanel configuration to a channel configuration file...
Best regards
(4,870 Views)
