Controlling Vector CANoe through ActiveX in LabVIEW
Hi. I am using Vector VN1630A Hardware to communicate to the Unit Under Test through CANoe. We are trying to control the CANoe through ActiveX in LABVIEW. So need to know how feasible it is to control the CANoe through ActiveX in LABVIEW. Is there any document which explains in detail the controlling of CANoe through ActiveX in LABVIEW. Have anyone done this before. Can anyone share me some sample code.
(4,969 Views)
Is this post is still open?
(4,766 Views)
This question has been asked before.  Try these links:
https://forums.ni.com/t5/LabVIEW/Active-X-and-Vector-CANoe/td-p/414803
https://assets.vector.com/cms/content/know-how/_application-notes/AN-AND-1-117_CANoe_CANalyzer_as_a_...
https://assets.vector.com/cms/content/know-how/_application-notes/AN-IND-1-011_Using_CANoe_NET_API.p...
Also look in the Example Finder for general background into ActiveX.
Did you consider using CAPL within CANoe to automate the testing?
Ian
(4,720 Views)
