This widget could not be displayed.
LIN bus read header frame
Hello All,
i have need to listen all data on LIN bus.
I created VI, that works nice if there is full frame on lin bus (ID + data).
But in case that there is sent only header frame (only ID), and there is no answer from some node, labview shows LIN BUS ERROR frame.
I decoded data packet and get ID from byte 6.
Is there is way, that labview detect only header frame, and not LIN BUS error..
Thank you.
Milan
(2,592 Views)
Your picture is not visible, at least for me.
Which LIN interface do you use ?
Have you tried to enable the error logging ?
In the examples of LabVIEW, you will find "LIN Bus Monitor.vi" which uses the NI CAN Frame API (not NI-XNET). Have you tried it ?
(2,540 Views)
