Crazy times starting an xnet session
While creating an xnet session, I have a signal "RC" causing a -1074384764 (signal not found) error if called from the signals array. If I call it by itself it causes no errors. Even if I delete it from the array the entire array errors out. I have been to every signal, one at a time, and started a session for each one with no errors.
(1,510 Views)
Can we see some code, something about that doesn't seem right.
(1,495 Views)
Accepted by pgaierDV
We had a signal naming problem with our .dbc file. I can't explain the weird behavior but I got it working so I'm not worrying about it. Thanks anyway, Brian.
(1,489 Views)
