Diagnostics On CAN-FD using NI-Xnet
Accepted by Rahul1189
you can set the custom baud rate as you can do in XNET. Refer to the XNET manual how to use custom  baud rates.
You also can use the XNET Editor or Bus Monitor to configure your custom rate and use that value ass your ADCS custom baud rate.
See screenshot as an example.
Message 11 of 13
(1,779 Views)
Thanks for the support.
Message 12 of 13
(1,776 Views)
I used ADCS error report
Message 13 of 13
(1,207 Views)
