ECUMC toolkit support Flexray?
Good morning:
my question is:
1. I got the client's A2L file and opened it with ECU MCtoolkit.
2.There is currently a USB-8502 CAN device on hand. Does the ECU MC toolkit support this device? 3. The recommended devices I saw on the ECU MC toolkit presentation page only NI PCI-8513/2 and NI PXI-8513/2 support only these two devices?
4.Does NI have devices that support both CAN,Flexray transport and ASAM XCP?
5. With a Vector 7640 device on hand, does NI have a driver package?
thank you!
(3,666 Views)
Accepted by dulan
The USB-8502 does support the ECUMC toolkit and is basically a USB version of a PCI/PXI-8512. Most XNET code that works on one should work on the other without modification.
NI has several product lines for CAN that fully support the ECUMC toolkit and offer ASAM XCP capabilities.
NI also has PCI/PXI-8517 devices that support FlexRay communications, however, XCP with ECUMC is not currently supported on our FlexRay devices.
You will have to check with Vector for 7640 driver packages.
Jeff L
(3,644 Views)
thank you
(3,638 Views)
