Error 0xBFF63092 with NI 9862
I am trying to read out CAN Data with the NI 9862 Module and a cRIO 9024 / cRIO 9114. At first I wanted a simple readout of some signals which came from a database file.
Unfortunately I get an error (Hex 0xBFF63092), which is explained as "Session not found in project". As the session is in my project, I don't see how to solve this problem. Can you help me with that? You can find a screenshot of my project attached to this post.
Thomas
(6,864 Views)
Hello Thomas,
could you please upload a screenshot of your LV-project with your FPGA Target expanded? How did you create your XNET-Session (Testsession)? What kind of data do you want to read? How configured you the Loop Timer function in your VI (ms, µs or Clock)?
Cem
(6,810 Views)
Hey Cem,
as FPGA-VI I just compiled a blank VI before trying to run the RT-VI. Xnet support should be available after doing that. The Xnet Session was created by right-clicking on my cRIO Target in project explorer and importing a .dbc file. I wanted to read signals single-point. The Loop Timer was configured as ms.
The problem was meanwhile solved by creating the XNET-Session in the RT-VI itself via "Create Xnet Session" and selecting the signals which should be read at that point. Curious that it does not work the other way.
Best Regards
Thomas
(6,503 Views)
