Error-8706 occured at Add Channels from File.vi
Iam trying to run the examples provided for USB_CAN in the CAN Frame Channel Conversion Library. When I hit run after loading the database file(.dbc) It is showing me an error saying "Error-8706 occured at Add Channels from File.vi" Do any one know how to get rid of this error.
Thank you
Shanth.
(6,338 Views)
Shanth,
Is the error number 8706 all that the message gave you, or is there additional error information, such as a possible reason or solution?
Eric K
Applications Engineering
(6,316 Views)
