Log file to Channel conversion
Can anyone help me out? I was wondering how to convert the logged data from the CAN bus to different channels. I was able to to record the frames from the CAN Bus to a Log file. Now I want to parse this frames and to figure out the individual messages in the frame. I looked the example provided by NI for converting the Log file as frames but I need to convert it further i.e log file to frame and then frames to channel.
Thank you.
(6,247 Views)
Have you seen the frame to channel conversion libraries?
Matt
Matt
(6,227 Views)
