Flushing Message queue
Is there a way to flush the message qeue stored in the NI CAn bus card? of
for that matter how can I reset the NI CAN card as is done on a Power Off
power On? I am using LabWindows CVI.
(5,384 Views)
There isn't any API call to flush the CAN queue.
You can use ncReset to put the CAN board on its power on state. The function actually reloads the board's firmware, so it resets the board just as if it was powered on.
Check the following knowledge base article:
Using the "ncReset" function with NI-CAN
DiegoF
National Instruemnts
(5,380 Views)
HI,
The  knowledge base article is not available !!!
Smiley Surprised
(5,121 Views)
The KB is no longer available , because we do not recommend to use the ncreset anymore. Instead use the ncaction with reset option to flush the buffers.
For a power on and off, you need to reset the board from MAX. (CTRL+ SHIFT and right mouse click to the board).
DirkW
(5,109 Views)
Is there a way to do this with the Channel API and the associated VI's?  If not, can the ncaction be used along with the Channel VI's?  I need a way of shutting down any tasks which are running.
(5,090 Views)
unfortunately there is no reset option available for the channel api. But normaly the task clear function should clear the buffer too.
DirkW
(5,043 Views)
