vi to manipulate test panel line 0 & 1, output port 0, PCI-6503, High & Low
I need to develope a vi that will manipulate lines 0 & 1 of output port 0 High and Low in the test panel for PCI-6503 CAN card in MAX.  Line 0 wil be a constant High but line 1 will be a timed pulse starting Low then pulsing High and then returning to a steady state Low.  Any thoughts?
John Ely
(3,685 Views)
Hi John,
Are you referring to the NI PCI-6503?  It sounds like your question is regarding digital output with this card.  If so, I think it would be better to post a new thread on the Digital I/O Board
If you are using CAN, could you double check and see what CAN card you are using?
Have a great day!
Adam W
(3,673 Views)
