GMLAN & PCI CAN
Hi ,
I am using NI PCI-CAN/2 Series 2 for validation purpose . Can i use same hardware(i.e. PCI CAN CARD) for testing the GMLAN protocol.
Thks in advance
HKT
(9,033 Views)
See the following KB Link for more informations:  Link
DirkW
(9,018 Views)
Hi DriKW,
link you have provided is not working here , can you share the content of the link .
there is one more question :-
Can we pragmatically select the Low speed(33.33kbps, single wire) mode in PCI CAN series 2 card ?
Thks in advance
HKT
(9,003 Views)
Ups that was the wrong Link:
GMLAN is based on the CAN architecture so technically it should work with NI-CAN hardware. The reason why we cannot say it is supported is because in order to have a hardware that is GMLAN compliant, it must be certified by GM. Since there hasn't been a considerable number of customers who request this support, we have not made that yet.
Second question:  Only the 8464/XS board allows to switch transceivers programaticaly to Single Wire CAN. Our High Speed boards are limited to 40 KBaud minimum.
DirkW
(8,987 Views)
Hi. Lab V,
I am also interested in working with the GMLAN Protocol with the NI Card.  I'm a novice and maybe you can guide me along. Thanks
(8,951 Views)
Any suggestions on how to enquire PID status via GMLAN will be appreciated. I have an X-NET card and a GMLAN supported ECU.
Certified LabVIEW Architect
(7,607 Views)
