pcan usb
Good afternoon.
I am currently trying to communicate via CAN, with PCAN USB.
However I am not able to connect.
With the PCAN explorer I communicate. However I can not do with LabVIEW
I tried with the libraries of pcan but nothing done
somenone can help me?
(8,082 Views)
Hello c-m
If you want to use an non NI USB device refert to this link in order to be able to communicate with it. http://zone.ni.com/devzone/cda/tut/p/id/4478
Another solution would be to use the drivers given by your manufacturer. Because we don't have acces to the PCAN libraries, If you have trouble to use it, I encourtage you to contact your  manufacturer directly.
Alexandre M. | Certified LabVIEW Developer
Embedded and Control Systems Engineer (NI France)
(8,070 Views)
Download the code from here:
http://www.labviewportal.eu/en/device-i-o/82-pcan-usb-driver
This works.
(7,222 Views)
