How can I get a USB-8473 to work at >125kbps?
All,
I am using an NI USB-8473 high speed CAN card.  I've plugged in into a known-good CAN port in a network that works fine at 500kbps with other CAN devices.
When I run the 8473 at 125Kbps, it works fine.  When I run it faster than that, it does not work.  It does not read CAN data, although the CAN LED does flash before an error (3FF6206B or other) is generated.  When I try to write to the bus at speeds above 125K, the device appears to attempt to write once, then stop functioning.
Any help would be greatly appreciated.
Thanks!
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(8,969 Views)
  • Although the network works with another interface at 500kbps, please check if your cabling meets the requirements for High-Speed CAN (page 4-4 of the NI-CAN Hardware and Software Manual).
  • Do you use proper cable termination as mentionned at page 4-5 of above linked document ?
  • Has the "know-good CAN port" an onboard 120 ohm termination resistor ?
(8,963 Views)
Cabling meets all requirements for High Speed CAN and works with other CAN hardware.  Termination resistors are 120K.
Thanks for your input.
- Forbes
Forbes Black
(8,956 Views)
Accepted by diarmaede
120KΩ or 120Ω ?
(8,951 Views)
At this juncture, I must quote the famous philosopher, Homer, not once, but twice.
Quote #1:  "D'OH!!!"  You mean orders of magnitude are important?!
Quote #2:  "Woohoo!"  Problem solved.
Thanks for making me see the obvious.
Cheers,
Forbes
Forbes Black
(8,947 Views)
