How can I set up timed transmission in NI-CAN
I want to get a timestamp from the NI-CAN card whenever a frame is transmitted successfully. Similary to the timestamp I get when reading messages. How can I configure the NI-CAN card to support timed transmission?
Best regards
Edgar Vorland
READ Matre Instruments AS
Norway
(3,922 Views)
There's no direct way to read the value of the timestamp for an outgoing frame.
One indirect way of getting the timestamp is to use a wait function (or notification in C) configured to detect a Write Success event. When the wait returns you can use the GetTimer function to retreive the timestamp value of the NI-CAN driver. There would be some sort of error.
For more accurate timing you could use the RTSI bus to generate a pulse after a frame has been transmitted. The RTSI signal can be timestamped by a counter board (or another CAN board configured for Timestamp on a RTSI event).
Let me know if you have any questions.
DiegoF.
(3,922 Views)
