How do i create a high voltage wake-up message?
I have a NI-CAN/LS2 card. I need a high voltage wake-up Message to get a device working, how do i create one?
(4,401 Views)
NI-CAN cards are not able to send a high voltage wake-up message. At 15V pulse is usually used for this purpose. You can use a third-party device to generate the pulse, however, at this point National Instruments does not test the cards for this.
Have a good day.
Kim L.
(4,401 Views)
