How to Connect LS CAN (USB-8472) to Single-Wire CAN device?
In the post of http://forums.ni.com/ni/board/message?board.id=30&message.id=216&requireLogin=False , NI Engineer said that
It is possible to use our Low-Speed CAN boards in a single-wire mode. However, the board will give CAN warnings. So, the control program may have to ignore certain CAN warnings.
Randy Solomonson
Application Engineer
But I can't see the detail connection and software settings in that post.
 How can I use LS CAN to communicate with single-wire CAN (such as GMLAN)? Should I make some additional settings in my LabVIEW program?
帖子被hmqi2002在 07-09-2009 04:07 AM
时编辑过了
Message 1 of 1
(7,057 Views)
