Pb to receive a message with the examples Channel Monitor.vi or CAN receive.vi (they don't work)
I want to receive a message with this examples of Labview on the CAN bus, when I send a message I see it with the bus monitor of MAX, but I can't see it with the examples of Labiew...
Somebody has test this examples?
(6,313 Views)
What's your LV version ? What Can device do you use ? You can test the CAN Receive.vi with the CAN Transmit - event based.vi with the CAN Virtual Ports first, and after with your physical device. You can simulate 2 CAN ports directly in your code. CAN ports CAN256 and CAN257 are virtual ports that are already created when NI-CAN version 2.3.2 and above is installed.
Then, you can use the CAN Bus Monitor through LabVIEW using System Exec.vi. I have attached a sample VI made in LV 8.6. Also, there are some interesting threads wich may help you.
Cannot get NI-CAN to send/receive messages via LabVIEW
Having trouble transmitting to CANbus using LabView
CAN Channel Monitor
Let me know what happens.
Steve M.
(6,280 Views)
