How to connect NI low-speed-CAN board to a single-wire-CAN bus?
I need to connect to a single-wire-CAN bus. This bus is often used in cars. I need some advice on how to do the physical connection from dual-line to single-line.
Or if there is a device that I can use for this purpos.
(4,720 Views)
Hello-
It is possible to use our Low-Speed CAN boards in a single-wire mode. However, the board will give CAN warnings. So, the control program may have to ignore certain CAN warnings.
Randy Solomonson
Application Engineer
(4,720 Views)
You could give more details...
(4,720 Views)
