How to programmatically get the serial number of DeviceNet card?
I'm using LabVIEW 6.1 and NI-DAQ 6.9.3.
I notice that in MAX 4.0.2 the serial number of my PCI-DNET card comes up.  Is there some way I can access this programmatically in LabVIEW, either thru the DAQ driver or via the NI-DNET (version 1.4.1) LabVIEW driver?
(4,553 Views)
You can get the serial number programmatically by calling ncGetHardwareInfo.vi in the NI-CAN API with the appropriate attribute set.
Robert Mortensen
Software Engineer
(4,541 Views)
Thanks!  That worked perfectly.  Another thing I'm attempting to do is programmatically retrieve the (device-specific) input/output lengths necessary for I/O connections.  I can get this of course using the Get DeviceNet Attribute.vi using classID 5, instance ID 2 (e.g.), attribute IDs 7 & 8.  However, this will work only AFTER the I/O connection has been opened; and to open the connection, I need to have this information!
SimpleWho appears to retrieve this info somehow (perhaps thru the CAN driver).  Any ideas on how I can mimic this behavior from within LabVIEW (versions above)?
Thanks!
(4,535 Views)
<Waving off>
I was able to get the input/output lengths via another discussion thread: http://forums.ni.com/ni/board/message?board.id=30&message.id=1913
</Waving off>
Smiley Wink
(4,519 Views)
