How to read a particular arbitration id from CAN bus
Hi All,
Sorry to start in between.
I have modified one CAN example given with labview 7.1. As per my understanding this VI should read the message depending upon the "Frame Format Selector" control.
If it is Standard then the VI should read only standard frames not the extended
& if the input to "Frame Format Selector" control is extended then the VI should only read extended frames not the standard.
But this VI is reading Standard frames also while the "Frame Format Selector" control is extended.
Kindly tell me why it is happening like that. This VI should only read either of Standard or Extended depending upon "Frame Format Selector" control.
I ahve attached the example for your reference. It is in labview 7.1
regards,
J
Message 11 of 13
(4,482 Views)
J:
See my response to this question in the " Issue with CAN example given with Labview 7.1" thread.
Bill
GCentral
Message 12 of 13
(4,453 Views)
Hi
Thank you very much for the usefu link.for more information visit our web site [url=http://www.machinesindia.com/search/searchproduct.aspx?stext=EOT%20Cranes]EOT Cranes[/url]
Message 13 of 13
(4,266 Views)
