I have to start MAX for recognizing an other CAN USB device
In my project I use a USB CAN converter (NI USB-8473). I have several adapters for different customers. When I connect an other adapter than was connected before, my LabVIEW program only recognizes it when I start MAX.
The adapter receives the same address CAN0 as the previous adapter, but obviously not before MAX is started. This happens when an executable is run (on a computer without LV) or on the LabVIEW development system. I do not have to stop my program.
Why is this? Can I trigger the detection of the converter out of the program?
Greetings,
shb
(11,854 Views)
Accepted by shb
Hi shb,
I have tried to reproduce the issue that you are describing with one USB-8472 and one USB-8473. Using the LabVIEW NI-CAN example <LabVIEW folder>\examples\nican\Frame - Basic.llb\CAN Transmit - event based.vi, I could stop the VI, unplug one USB device, plug in the second and re-start the VI without causing any errors...
May I ask you which NI-CAN driver version you are using? I have used the latest one, NI-CAN 2.7, which is available as a "side installation" from NI-XNET (setup.exe can be directed to only install NI-CAN). You can find the download here:
NI-XNET 1.1 - PharLap, Windows 7 64 bit/7 x86/XP/Server 2008 x64
If upgrading does not resolve this issue, I will try to get hold of a second USB-8473 to exactly reproduce your setup...
Best regards.
Sebastian
(11,810 Views)
Hello Sebastian,
I will try NI-CAN 2.7 on Wednesday. Currently I use NI-CAN 2.6.3. I hope to mark your post as solution thereafter. Anyway, thank you verry much.
Greetings,
shb
(11,808 Views)
Hello Sebastian
This did the trick. Thank you very much. This is the solution plus a kudo at least.
But I have two questions:
- Why is NI CAN 2.7 shown as 2.6.2 when building an installer in LabVIEW? In MAX the version is shown correct.
- Why does CAN 2.7 depend on LabVIEW 8.2.1 Runtime Engine? This does not make sense to me. And I do not have this installer CD here...
Greetings,
shb
(11,787 Views)
Hi shb,
the indicated version 2.6.2 of NI-CAN during the creation of an installer/deployment is just a cosmetic issue NI R&D already knows about. It is filed under the reference CAR# 214017 and should be fixed in an upcoming version of NI-CAN.
As for the dependency on the LabVIEW 8.2.1 run-time engine, I can only guess that maybe NI-Spy (which is included with NI-CAN) is programmed in it. If you have downloaded NI-XNET 1.1, you should find the necessary setup msi file in the following directory:
<extraction directory>\Products\LabVIEW_Runtime_Engine_82\lv82rte
Sebastian
(11,750 Views)
