I've a problem with my CAN configuration. I use Windows NT, my Card references is PXI 8461, I use a computer PXI 1000-B.The problem is :
I failed all the time when I use CAN Diagnostic to test the connection CAN 0 and CAN 1. I would like you to help me. Thanks for all.
(4,376 Views)
And You didn't forget to use the NI-CAN Configuration Utility?
With this utility the ni-can card must be setuped before testing it.
Golubkov Andrej
(4,376 Views)
The suggestion made by Golubkov is correct. Make sure that you have configured the CAN objects to correspond to the Ports- for instance, Port1 to CAN0 and Port 2 to CAN1.
If this dosen't fix the problem, let us know what the error message clearly states ( can be found out by clicking on the details tab).
(4,376 Views)
