I would like to know if NI sells hardware which, connected to a PC, can convert numeric datas into an analogic signal (voltage).(France)
I have to make a simulation of a fill computer from data stocked in a PC. I would like to know if National Instrument sell an hardware which, connected to the PC, can convert numeric data into an analogic signal (voltage)
If it is the case would you mind directing me to someone in france who can send me a brochure of that hardware
(3,425 Views)
This link shows all of NIs Analog Out hardware. There are units for PCI, PCMCIA and PXI.
All of these generate a voltage +/- 10VDC and can be easily programmed with any of NIs software packages.
There are also Multifunction DAQ cards that each have 2 analog outputs, digital IO, counter/timers and a variety of analog inputs.
If you hit the MyNI link on the upper left of this page, you should get the name and number of your local NI representitive. They would be the best way to get more details on what you might need.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(3,425 Views)
