Is NI-CAN threadsafe?
Can I use NI-CAN functions like ncwrite,ncread etc. simultaneous in 6 different threads? I have three PXI CAN-2port cards, 6 ports configured as separated CAN-objects.
(3,824 Views)
From what you described, you want to handle each port in a separate thread. If that is the case, you shouldn't have any problems.
They only problem I've seen is using ncWait in to threads for the same CAN object.
DiegoF.
(3,824 Views)
