Is it possible to create .ncd file without using MAX?
Is it possible to create .ncd file without using MAX? I am trying to read the data given by hundreds of possible Arb. IDs on one of the CAN port without having to create it from the MAX.
Thank you
(5,490 Views)
the NI-CAN driver software does not provide functions/VIs to generate *.ncd files. However the *.ncd file format is just plain XML (ASCII text). Take a look at the example.ncd file that gets installed with NI-CAN (<ProgramFiles>\National Instruments\NI-CAN\):
<?xml version="1.0" encoding="UTF-8"?>
<nican_config version="0.1">
<saved>8/8/2005,17:58</saved>
<message name="TransmissionFluids">
  <id extended="0">82</id>
  <dbc>C:\Program Files\National Instruments\NI-CAN\example.ncd</dbc>
  <conflicts>0</conflicts>
  <bytes>6</bytes>
  <interface>1</interface>
  <comment></comment>
  <channel name="ClutchPressure">
    <bitfield start="0" bits="8" order="0" type="1"/>
    <linear_scaling factor="1.600000e+001" offset="0.000000e+000" max="4.000000e+003" min="0.000000e+000" default="0.000000e+000" unit="kPa"/>
    <comment></comment>
  </channel>
</message>
</nican_config>
Thus, you could generate *.ncd files with simple file I/O. Having XML-specific file I/O functions simplifies this task.
-B2k
(5,475 Views)
Hi bus monitor. It's possible to create a ncd file programmatically. See the link below.
http://decibel.ni.com/content/docs/DOC-3456
My regards,
Vinicius
(4,665 Views)
