Is it possible to send 2 different messages over a CAN network (by the NICAN board)with different periods ?
Example: Message 1 (ID 001) every 10 ms and Message 2 (ID 002) every 20 ms at the same time ?
(4,733 Views)
Yes. It is totally possible to do this. Attached is an example that can be slightly modified. Simply add another set of VI's to open a second CAN object, write to it and close at the very end.
Randy Solomonson
Application Engineer
(4,733 Views)
1.I should add another set of CONFIG, OPEN andWrite to the second message ?
2.In the diagram I noticed that the Write Function doesn't keep running every loop. It runs only when the data message is different from the previous. Is it correct ?
(4,733 Views)
Was the reply the exact answer to your question or would you still like to get another example?
(4,733 Views)
