"How do I control the TEK TDS3052 by LABVIEW installed in a PC?"
I used the "crossover" cable directly connect the PC and the TEK TDS3052(with a ethernet port).What I have done is that I configured the ethernet parameters( the IP adress, the net mask etc.). And when I apply the "Ping" command in the "run" window of the windows 98, there is a correct return.So the ethernet network is well done.Now I want to use the LABVIEW to control the oscilloscope. But I don't know how to do then.Who can tell me the detail steps which I can take next, thanks a lot.
(4,197 Views)
The answer to this question has more to do with the scope than anything else. Basically, you will most likely use LabVIEW to send the scope textual commands via TCP, if the scope does in fact have this functionality. I say this because generally, GPIB is used to interface with instrumentation rather than Ethernet.
LabVIEW comes with several excellent examples including those which illustrate using TCP to send and receive text messages. Please review these LabVIEW examples and apply them to the information in your scope's documentation.
If you ahve futher inquiries, please direct them to the Developer Exchange > LabVIEW General discussion forum rather than the Industrial Networks forum.
(4,197 Views)
