J1962M Cable to connect to NI-8473
I am tring to "hack my car" using NI-8473s CAN interface to a J1962 OBD-II connector.  I have the Automotive Diagnostics Toolkit, but want to order the proper cable to go from the J1962 to the NI-8473.  An adapter would also work as I also have the 192017-02 cable (DB9F to DB9F I think).  Do you have a source for connecting to the OBD-II?
Thank you.
__________________________________
Laine
(6,990 Views)
Laine,
Glad to see you are taking advantage of the CAN network in your car.  The cable I used was the ValueCAN OBD Cable from Intrepid Control systems: http://www.intrepidcs.com/
It's about $25 if I recall correctly.
--Paul Mandeltort
Automotive and Industrial Communications Product Marketing
(6,976 Views)
Thanks Paul.  I found it, but they have a min $100 order, so I looked around for others and found a number of pinouts, to wit:
http://intrepidcs.com/catalog/product_info.php/cPath/32/products_id/38?osCsid=c4959b6a089a95f331464348bf1f09c9
http://www.bb-elec.com/bb-elec/literature/obdiij.pdf
http://www.obd2cables.com/products/product_info.php?products_id=31&osCsid=b3f01d97f8b342a12d0caabe5ca34b26
http://www.scantool.net/products/product_info.php?products_id=22
http://allobd.com//proddetail.asp?prod=OBD2-obd2cable
Looks like Intrepid is the only one to match up correctly.  Is this a weird pinout?  I think we will just go flying leads and make a connector.
Laine
Laine
(6,969 Views)
