Multiplexe​d CAN signals Conversion with XNET
Hello all,
I’m using NI XNET Conversion to convert CAN Frames to Signal Data.
As per my attachment this is working fine but, when I’m giving Multiplexed Signals then its giving Error.
Error Code:   “ 1074384751”
                                NI-XNET: (Hex 0xBFF63091) For Signal Output sessions, the multiplexer Signals used in the session must be specified explicitly in the Signal list.
Please help me how can convert CAN Raw Frames to Signal values for these kind of Signals.
Thanks & Regards
Munna
Munna
(8,604 Views)
Hello all,
Please let me know if anyone have idea about this issue.
Best Regards,
Munna
Munna
(8,584 Views)
Hello all,
Please respond to this.
Best Regards,
Guru
Munna
(8,543 Views)
I have had luck adding the command byte channel to my signal list. The command byte data will then be in you data. I just ignore it.  I add this channel above the signal it corresponds with.
(8,525 Views)
Accepted by Munna232
Hello all,
Thank you so much for support as always.
Yesterday I solved this issue..  Its explained in XNET User Manual..
Sorry for late reply.
Munna
(8,513 Views)
Hello Munna,
Can you please tell me where in the Manual did you find it? I have exactly the same problem and I just can't find any solution for it... thank you.
(6,122 Views)
i am facing same issue. Any solution for it?
(3,866 Views)
