NationalInstruments.DAQmx.DLL' could not be loaded in C#
I tried to load the NationalInstruments.DAQmx.DLL in Xunit of  C#. We can build the solution, but it failed when running it. The error message is "Result Message:
System.TypeInitializationException : The type initializer for 'GM_GlobalB_Tests.DiagnosticDTCTests' threw an exception.
---- System.IO.FileLoadException : A procedure imported by 'NationalInstruments.DAQmx.DLL' could not be loaded."
(3,850 Views)
May I know what version of DAQmx you are using?
This problem looks similar to:  Procedure Imported by 'NationalInstruments.DAQmx.dll' Could Not Be Loaded
(3,818 Views)
Accepted by judy_chen
I am using the 15.1 DAQmx, and after updating the DAQmx to 17.0, the problem has been disappeared. So I can use the DAQmx now.
Thanks for your help.
(3,803 Views)
