NiCan Check Connection
Hello there,
I am using NI USB 8473. How do I create a log file to store the transmitted and received data? What function should I call in Borland C Frame API to create the data log file?
Thank you in advance.
(4,491 Views)
Hello Slytherin,
Have you seen the NI-CAN Hardware and Software Manual?  Chapter Eleven in that manual covers all of the C functions for Frame API.  Logging the data to a file would not be a specific Frame API call.  Once you've read the data, you can then save it to the type of file you want using a standard C function.
Thanks!
Meghan
Gryffindor Fan
(4,476 Views)
