PCI-CAN\2
Is it possible to simulate the PCI-CAN\2 like other devices in the MAX?
jo
(6,224 Views)
Hello Jo,
thank you for posting at the National Instruments Forum. It is not possible to simulate a CAN-Device in Measurement and Automation Explorer, like you maybe know from our DAQmx-Devices.
If you like to test an application, you may use the virtual CAN interfaces 256 and 257. Both are created when you install the NI-CAN driver. Both devices are virtually connected and all frames, which are sent to the interface 256 are transferred internally to 257 and vice versa.
I hope, that this information helps you.
Best regards
Marian Vorderer
(6,210 Views)
