PXI-8532 self test
Hello
We use a PXI-8532 devicenet board and are looking for a way to test the board.
Is there a way to do a self test ore some other way to test the board ?
(3,629 Views)
Hi Tonnie,
NI PXI-8532 doesn't support the self-test. And NI provides some examples of DeviceNet. I would suggest that you run the examples after adding a device to PXI-8532.
Zheng
(3,617 Views)
Accepted by Tonnie
Hello
It's a pity that this is not possible and that there is only a LabView driver available. In the past there was also a CVI driver available.
The LabView driver can't do what we want with this board. This was different with the CVI driver
(3,167 Views)
