Power supply PCMCIA
Must I connect V+ in my low speed port (CAN/DS) if i use a PCMCIA CAN/2?
Thancks
e.c.
(3,777 Views)
You must have the Two port low speed cable adapter, part number: 186855C-01. In this cable the transceiver is internally powered, so there is no need to power the transceiver from the bus.
DiegoF
National Instruments.
(3,777 Views)
