Problem of communication between PCMCIA CAN/2 and simulator
I have a PCMCIA CAN/2 Card. I would like to test the reception of CAN messages. So I have a Netway card wich simulate CAN messages.
I can see messages sended by Netway card on an oscilloscop.
I have connected the Netway card to the DB9 of the PCMCIA CAN card ( GROUND H-CAN and L-CAN)
I launch the simulator, and when I launch the bus monitor on "Measrurement and Automation explorer" I don't have nothing, in the same time i see the message on oscilloscop.
Thanks for your help.
(6,314 Views)
If you connect  to a CAN Interface for the first time, there are a number of things that can go wrong.
Maybe this link will help you ...
 Re: Cannot get NI-CAN to send/receive messages via LabVIEW
good luck
Anke
(6,303 Views)
Thank you very much, the problem was about the 120 Ohms resistance between CAN-L and CAN-H.
I can read now my messages CAN.
(6,295 Views)
