Using frame and channel API at the same time.
One of our customers specified the channel-mode number except programming the serial. So I have to use the channel api and the frame api at the the time! Is it possible with a 2 port PXI card like PXI-8461/2 (Port1 for channel api and port 2 for frame api)?
(6,151 Views)
Yes, you can have one port for channel api and one port for frame api. But you cannot mix on one port.
DirkW
(6,147 Views)
