Read Serial Number in LabVIEW of USB-8476 LIN Module
Is there any way to read the serial number of a USB-8476 module in LabVIEW. I am building a system that will use 10 of these modules in one system and I want to be able to verify that LINX = serial #:ABC. I am concerned that a "user" will unplug and plug-in a USB module causing the LIN number to change.
(7,480 Views)
Accepted by Gleichman
Hi Gleichman,
The ncGetHardwareInfo.vi with the attribute set to "Serial Number" should do the trick (use the desired USB interface, and port number 1 as inputs).
-B2k
(7,472 Views)
Hidden in plain sight! Thanks.
(7,459 Views)
