Read Signal Encoding from LDF file using XNET
Does this limitation also extend to other XNet protocols?  I have a CAN DBC with a defined value table, where 0 might mean "Ready" and 1 might mean "Not Ready" and showing this text on the UI would be nice, and I'd like to get this information from the DBC, instead of hard coding it.  If this is true I don't know how this feature was overlooked by NI for so long.
Message 11 of 14
(4,807 Views)
I do not believe the limitation applies to *.DBC files as we have the XNET Database Get DBC Attribute.vi that appears to provide this functionality.
Jeff L
Message 12 of 14
(4,799 Views)
Yup you are correct this limitation isn't there for DBCs, still kudo'd the idea.
Message 13 of 14
(4,796 Views)
could you post a VI with this code?
Message 14 of 14
(3,942 Views)
