Read Signal Encoding from LDF file using XNET
I'm trying to read the signal logical text table in a LDF file. The infomation should be marked under the section "Signal_encoding_types". It indicates what the value means for the signal. For instance, a siganl "W_FAILURE" (8 bit) has the following table: "0-No Failure", "1-Hardware failure".
Is it possible to get this out using XNET or any other LIN methods? The LDF file is attached.
Thanks!
Message 1 of 14
(21,772 Views)
Hello!
The XNET API in LabVIEW can open LDF files. They are referred to as Databses.
You will find the functions in the Functions pallette under Measurement I/O > XNET> Database
You will find some examples in the NI Example Finder under
Hardware Input and Output > LIN > NI-XNET > Databases
Also see
https://www.ni.com/docs/en-US/bundle/ni-xnet/page/getting-started-labview-api.html
  Georg
Message 2 of 14
(21,736 Views)
Hi
Thanks for the reply!
It was the question because of the LIN Message encoding, which is explicit defined in the LDF file. I need to used this part to decode the messages on the LIN bus. I've known how to read the LDF file (databse). But I didn't find the option to read out the encoding table in XNET.
Message 3 of 14
(21,732 Views)
Does anybody have an answer to this question? I have the same problem: LDF read is OK, but I don't find the right property node for the signal's logical values.
Madottati
Message 4 of 14
(21,045 Views)
scaling LIN data into a String table value is not support of today by NI-XNET
Message 5 of 14
(21,043 Views)
in this way you can get the infomation of signal_Encoding_tables
regards
Melo
Message 6 of 14
(19,291 Views)
Like the other guys (wilburwu, EDAG_Ingolstadt and Madottati) I would like to read in a LDF file the signal logical text table that it is marked under the section "Signal_encoding_types".
It seems that in September 2016 (more than 3 ½ years after the opening of this topic) it is still not available with NI-XNET.
I am using NI-XNET 15.5 with LabVIEW 2012 and PXI-8516/2.
Can anybody from NI tell us if one day it will be done ?
I think it's a shame not to have this feature, because as wilburwu wrote a signal "W_FAILURE" (8 bit) has the following table: "0-No Failure", "1-Hardware failure" and it is more convenient to read a text than understanding a number.
Thank you.
Bravi
Message 7 of 14
(17,067 Views)
I can confirm that Signal Encoding Types have not been added to XNET as of version 16.0.
I will check the list of requested features to make sure signal encoding types is represented and update the request if it is. Unfortunately, I cannot predict if the feature will be implemented in the future or not.
Jeff L
Message 8 of 14
(16,989 Views)
As I see, there is an already declined idea in the Idea Exchange:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/XNET-database-editor-show-meaning-of-values/idi-p/3120...
The topic has been declined because nobody has kudoed it.
I created a new idea, please kudo it, maybe NI will take care then:
http://forums.ni.com/t5/LabVIEW-Idea-Exchange/XNET-database-editor-show-meaning-of-values/idi-p/3351...
Message 9 of 14
(16,973 Views)
Hi Jeff,
Thanks for your reply.
Hope that it will be done one day : especially as the information exists in the LDF file.
Bravi
Message 10 of 14
(16,970 Views)
