ā02-25-2013 04:28 AM
I'm trying to read the signal logical text table in a LDF file. The infomation should be marked under the section "Signal_encoding_types". It indicates what the value means for the signal. For instance, a siganl "W_FAILURE" (8 bit) has the following table: "0-No Failure", "1-Hardware failure".
Is it possible to get this out using XNET or any other LIN methods? The LDF file is attached.
Thanks!
ā03-05-2013
03:13 AM
- last edited on
ā04-29-2026
01:11 PM
by
Content Cleaner
Hello!
The XNET API in LabVIEW can open LDF files. They are referred to as Databses.
You will find the functions in the Functions pallette under Measurement I/O > XNET> Database
You will find some examples in the NI Example Finder under
Hardware Input and Output > LIN > NI-XNET > Databases
Also see
https://www.ni.com/docs/en-US/bundle/ni-xnet/page/getting-started-labview-api.html
Georg
ā03-05-2013 04:26 AM
Hi
Thanks for the reply!
It was the question because of the LIN Message encoding, which is explicit defined in the LDF file. I need to used this part to decode the messages on the LIN bus. I've known how to read the LDF file (databse). But I didn't find the option to read out the encoding table in XNET.
ā02-17-2014 12:03 PM
Does anybody have an answer to this question? I have the same problem: LDF read is OK, but I don't find the right property node for the signal's logical values.
Madottati
ā02-17-2014 12:06 PM
scaling LIN data into a String table value is not support of today by NI-XNET
ā05-27-2015 08:18 AM - edited ā05-27-2015 08:18 AM
in this way you can get the infomation of signal_Encoding_tables
regards
Melo
ā09-22-2016 11:01 AM
Like the other guys (wilburwu, EDAG_Ingolstadt and Madottati) I would like to read in a LDF file the signal logical text table that it is marked under the section "Signal_encoding_types".
It seems that in September 2016 (more than 3 ½ years after the opening of this topic) it is still not available with NI-XNET.
I am using NI-XNET 15.5 with LabVIEW 2012 and PXI-8516/2.
Can anybody from NI tell us if one day it will be done ?
I think it's a shame not to have this feature, because as wilburwu wrote a signal "W_FAILURE" (8 bit) has the following table: "0-No Failure", "1-Hardware failure" and it is more convenient to read a text than understanding a number.
Thank you.
Bravi
ā09-26-2016 02:49 PM
I can confirm that Signal Encoding Types have not been added to XNET as of version 16.0.
I will check the list of requested features to make sure signal encoding types is represented and update the request if it is. Unfortunately, I cannot predict if the feature will be implemented in the future or not.
ā09-27-2016 12:51 AM
As I see, there is an already declined idea in the Idea Exchange:
The topic has been declined because nobody has kudoed it.
I created a new idea, please kudo it, maybe NI will take care then:
ā09-27-2016 01:41 AM
Hi Jeff,
Thanks for your reply.
Hope that it will be done one day : especially as the information exists in the LDF file.
Bravi
