Read & write in the same VI
I´m making a program using Labview that read and write in the same CAN bus. I have used ncWriteNet and ncReadNet. I can send and receive messages but the problem is that the messages I send from my program are not read by my program but are read in Max, so I´m sure I´m sending them.
How can read the messages i´m sending? Thanks
e.c.
(3,940 Views)
Hi E.C,
There isn't a way to read-back from a CAN port. The CAN port cannot read a frame that is being currently transmitted. This behavior is determined by the hardware (the CAN controller).
I assume that you are using another port to read the frames, using Bus monitor, right?.
DiegoF
National Instruments.
(3,939 Views)
Hi Diego,
some weeks ago i had the same problem. I phoned with NI-Support in Germany and they told me with the new generation of CAN boards and new software version there is a possibility to receive the echo.
NI will deliver the boards this year in fall.
Now who is right ?????
greetings
Juergen
(3,939 Views)
