Reusing same socket for some-ip
In TestStand,If we do settings inLabVIEW.ini(SocketSetReuseAddr= TRUE) for LabVIEW development adapter mode it is working fine. If we are running application in TestStand under LabVIEW deployment adapter. It doesn't work.
Can anyone please confirm where can we add the above (SocketSetReuseAddr= TRUE) in Teststand so that, my application would work in LabView deployment adapter mode.
(973 Views)
You are asking a question about TestStand but you mentioned some-ip in the title.
Can you explain further how are they related?
https://tmesystems.net/
(948 Views)
