Soft Requirements for XCP over CANFD other than ECU Toolkit 18.0 or above?
Hello, I am trying to establish an XCP connection over CAN FD and I do not have access to some of the properties under the ECU Toolkit such as "mcPropCANIOmode" then "2—mcCANioMode_CAN_FD_BRS". Notice the Enum grayed out.
My current system is as follows:
1. LabVIEW2018 SP1 f3
2. ECU Measurement and Calibration Toolkit 19.0
3. NI-XNET 19.1
4. NI-CAN 18.0
Is there anything else I need in order to have access to these properties?
Thanks in advance.
(3,290 Views)
the CAN FD props should be visible with your software stack. Have you tried starting with a fresh new VI or reinstalling ECU MC toolkit? Is this a VI which was created using an earlier version of ECU MC toolkit or is part of a LV library?
Kay
(3,228 Views)
Hello kayfh,
I did try a new VI and nothing. The ECU toolkit (v19) was freshly installed from v15 for the first time to try to solve the issue.
I am not sure what you mean by your last sentence, but basically as it stands now, I have a blank VI and I do not have access to all the property nodes that should be there.
Thanks for the reply.
(3,217 Views)
It looks like uninstalling the toolkit and reinstalling it solved the issue. Just strange because there was never any errors during the installation.
Thanks for all the help.
(3,201 Views)
