Identification of port / interface through XNET / ECU M&C Toolkit
I am confused about how to properly identify interfaces programatically.  Here is what I have (using LV2018 SP1 / XNET 18.5 / ECUMC 19.1) :
A PXI rack with one 2-port XNET card.  At the moment these interfaces are named 'CAN1' & 'CAN2'.  Sometimes these names swap over for no apparent reason, which may be why I am having trouble.
Q1.  I know I can set these XNET interface names in MAX, but can I set them in LabVIEW?
Meanwhile, in the project code:
I get an array of references to the interfaces.  (Names here are read-only.)
Using those refs I can define various XNET sessions.  All good so far.
To prepare for XCP comms, I define this string as the CAN_Port_ID.
That string is read, along with the protocol name 'XCP' into the ECU Select VI.
Q2. Does the String defined above need to correspond with the XNET interface name?  I suspect so.
Into the bottom of the MC ECU Select vi is a Ring constant ECUMC interface identity image.png.
Q3. How does this identity relate to the XNET interface?  Is there some way to programtically determine what the ref should be for a given XNET port?
Thanks all!
Ian
(3,138 Views)
Accepted by topic author IanDeaville(ZF)
you can browse and reconfigure the XNET interface names by using the "System Configuration API" VIs.
Use e.g. "XCP:CAN1@nixnet" as "Protocol and Interface", where "CAN1" is the name of the XNET interface set in MAX.
The "interface" input is used for older NI-CAN hardware only and can be ignored for NI-XNET hardware.
Kay
(3,069 Views)
Kay,
Thanks for the info.  So my code is now:
...exporting the array of XNET interfaces.  This is picked up here...
...where the String is extracted in the Format To String block.  I would not have got that by myself, I suspect.  So later on...
... we can select the XNET interface without any constant values, and with the old NI-CAN reference disconnected.  This all seems to work fine!
I will take a look through the System Configuration VIs later on, but for now this seems to have done the trick.
Ian
(3,050 Views)
