Identification of port / interface through XNET / ECU M&C Toolkit
I am confused about how to properly identify interfaces programatically.  Here is what I have (using LV2018 SP1 / XNET 18.5 / ECUMC 19.1) :
A PXI rack with one 2-port XNET card.  At the moment these interfaces are named 'CAN1' & 'CAN2'.  Sometimes these names swap over for no apparent reason, which may be why I am having trouble.
Q1.  I know I can set these XNET interface names in MAX, but can I set them in LabVIEW?
Meanwhile, in the project code:
I get an array of references to the interfaces.  (Names here are read-only.)
Using those refs I can define various XNET sessions.  All good so far.
To prepare for XCP comms, I define this string as the CAN_Port_ID.
That string is read, along with the protocol name 'XCP' into the ECU Select VI.
Q2. Does the String defined above need to correspond with the XNET interface name?  I suspect so.
Into the bottom of the MC ECU Select vi is a Ring constant ECUMC interface identity image.png.
Q3. How does this identity relate to the XNET interface?  Is there some way to programtically determine what the ref should be for a given XNET port?
Thanks all!
Ian
(3,136 Views)
Accepted by IanDeaville(ZF)
you can browse and reconfigure the XNET interface names by using the "System Configuration API" VIs.
Use e.g. "XCP:CAN1@nixnet" as "Protocol and Interface", where "CAN1" is the name of the XNET interface set in MAX.
The "interface" input is used for older NI-CAN hardware only and can be ignored for NI-XNET hardware.
Kay
(3,067 Views)
Kay,
Thanks for the info.  So my code is now:
...exporting the array of XNET interfaces.  This is picked up here...
...where the String is extracted in the Format To String block.  I would not have got that by myself, I suspect.  So later on...
... we can select the XNET interface without any constant values, and with the old NI-CAN reference disconnected.  This all seems to work fine!
I will take a look through the System Configuration VIs later on, but for now this seems to have done the trick.
Ian
(3,048 Views)
