I get the error code 1074388733 at CANconnectTerminals.vi when I try to synchonize a PCMCIA CAN and a DaqPad 6016.
Soft and driver configuration :
  - Win XP SP2
  - Labview 7.1 (with new nicantsk to avoid 'CAN Sync Start with NI-DAQmx VI problem with a Series 2 PCMCIA-CAN'
  - NI CAN 2.2.1f4 (I import CAN message protocol from a vector .dbc file)
  - DAQmx 7.4.0f0
  - MAX 3.1.1.3003
  - My VI (synchro.vi) joint to this message
Hard configuration :
Intel P4 3.06 GHz HyperTreading, PCMCIA-CAN/2 serie 2 (250 kBaud/s), DAQPad 6016, PCMCIA-CAN Synchronization Cable n°188791B-01.
Cabling : Trig_0 to PFI0/A StartTrig (PIN n°62), Trig_7_CLK to Freq_out (PIN n°64) and GND to D_GND (PIN n°63).
When I try to acquire data (single or multi waveform channels) from DaqPad only or PCMCIA CAN only, no problem at all.
Can somebody help me ?
Thx
Christophe14
