08-09-2006 07:13 AM
08-10-2006 08:24 AM
Unfortunately an object is allways build for one particular ID. Thus if you like to change the ID, you have to close the Object and to initialize and open a new one.
If you have such ID changes very often i would recommend to use the Network Interface Object (Port) which allows you to use different IDs with the Read function.
DirkW
08-10-2006 08:50 AM
08-11-2006 09:30 AM
Yes you can use the network Interface directly to write and read frames with different IDs.
See the attached example for more information.
DirkW
