08-08-2006 11:54 PM
08-09-2006 03:57 PM
08-10-2006 12:01 AM
Hello Angela
Thanxs for the reply.
Can we launch MAX also programmatically ??
Raman
08-10-2006 05:55 PM
Hello Raman,
The System Exec VI can be used to call any command line functions. This is the same as typing the command into the Run window from your Start Menu. You can call a variety of programs in this manner. So instead of the NI-CAN directory, you can replace the string with the location of the Measurement and Automation executable. In this case you can just replace the command line string with "C:\Program Files\National Instruments\MAX\NIMax.exe".
I hope this helps,
Angela
